I wrote some demo apps based on the SDK. They are available on github https://github.com/mattcallow/esp8266-sdk
There are 7 so far:
01blinky - simple blinking LED on gpio2
02blink2 - as above, but using timers
03helloworld - Guess what this one does! (Connect to the device at 9600 baud after programming)
04sysinfo - prints out some system information (again connect at 9600)
05i2cdemo - This one is not working yet. I've copied the i2c_master files from the IoT example, but still needs more work
06thingspeak - This one actually uses WiFi! It will connect to thingspeak and update a channel with an internal counter. Optionally, it can be configured to use the thingspeak talkback commands to remotely control an LED on gpio2
07switch - basically a copy of the IoT example - a work in progress. I plan to simplify this somewhat
Matt Callow
