Today I made a ribbon cable and wanted to test continuity between the two connectors using a multimeter. When holding multimeter probes in each hand it is nearly impossible to keep the cable still for testing. That's when I realized I could hold the connectors side by side in a Stickvise and the rest was a snap!
Check it out below.
A few weeks ago @haydn jones sent me a picture of his Stickvise clamped to a table edge as a quick wire spool holder - great idea! If you have used Stickvise for anything unusual, leave a comment - I would love to see more pictures!
