Electronic wheel truing stand
Building a electriconic wheel truing stand, which makes whel truing easier.
Ongoing project, see log for progress. Description will follow later.
For now some links:
View all 2 project logs
OneShot Willie wrote 11/15/2014 at 03:12 point
I'd have a wheel on a shaft that is spring actuated in a larger shaft where you could essentially measure the resistance created by the overlap of the inner and outer shafts, like a rheostat. If you kept up with how much the wheel traveled, you could run the rim around to the spot you want to correct...
