We have pretty much finalized the changes to Rev 1.1. In addition to the gerber bugs mentioned in previous logs, we have made the following changes:
- Enlarged text for easier readability
- Improved the mounting holes
- Added an optional TVS diode on the I2C lines (I have managed to kill the I2C lines on AVRs in the past, and I suspect ESD damage... apparently these lines are more susceptible to ESD than other pins)
- Minor routing improvements
The updated board can be seen below:
I am planning on batching this on my next PCB order (which will likely be for my power supply boards)
The Big One
