I'm still waiting on a few parts (namely 0402 dropping resistors for the LEDs), but I got one v06 prototype partially assembled last night--and I can talk to the ATtiny88, so I must have done something right with the design!
You may have noticed the six pads on the back of the board design--I wanted to try pogo-style programming, since that's what we'll use when we ramp production up a bit. I deliberately made the pad locations symmetrical along the long axis of the board, intending to use one of the six prototypes as a base for programming (along with some hastily soldered together FR-4 as an alignment rig):
[note: someone at the #Hackaday SuperConference 2015 gave me a few googly eyes that made their way onto my USBtinyISP. Who was that? Thanks!]
The note already tells you something is wrong; during handling I managed to snap off one of the pogo pins. Turns out 1.5mm diameter pads break pretty easily. It's the MISO pin, so I re-purposed the ground plane and added a "splint":
Hilarious but ultimately ineffective--soon after taking this picture I snapped another pin off. Lesson learned--use insertion-mount pogo pins and take the time to make a custom carrier board! In any case, I decided to mount the pins directly to the FR-4; I had to tweak the alignment of a few to get a reliable connection, but this setup worked. I made sure to give each pin a generous copper pad so it wouldn't break off as easily:
I also scavenged a NeuroTinker logo off the scrapped board. The solder mask pullback + ENIG copper logo turned out pretty well, so I figured it was worth highlighting.
Oh yeah, and I didn't remember to implement one of the important lessons I learned when I put together v04: 4-pad SMD LEDs are a PITA to hand-solder and including a bit of extra pad goes a long way. The red/blue dendrite LEDs check out with the continuity tester, but we'll see if they actually work...
zakqwy
Errr.. I think the googly eyes have to be mine . Welcome :D
Membrane potential LED test (100% brightness, which overloaded my camera a bit):
http://imgur.com/bM2vaHl
If you haven't already seen it the sparkfun production and test board tutorial is great.
They use PCB for all the layers to build a jig.
Files for the first example are available in eagle for you to look over
https://www.sparkfun.com/tutorials/138
great article--thanks! I think Adafruit did a writeup on test boards that I read at some point, but I hadn't seen this one before. I'll definitely plan to roll some of these concepts into the production design.
The 2nd board down should prevent pogo pin snapping.
Also checkout the tagconnect as its an off the shelf solution. I saw it at ARM TechCon and I'm going to put it on a future board http://www.tag-connect.com/
