Today, Hackaday.io, you will be my rubber ducky. This log will cover implementing a crude approximation of Izhikevich neuron dynamics on a really cheap Atmel processor. In case you missed it, I discussed his model in the previous log, along with all the silly ways I corrupted the math in an attempt to make it run faster on an 8-bit, 8 MHz microcontroller.
First, a quick pseudo-code overview of the firmware:
int [a whole bunch of global variables]; main() { SystemInit; for(;;) { waitforISR; checkDendrites; calcDendrites; calcMembraneCurrent; calcIzhikevichModel; if (firing) {fire;} calcLED; updateLED; } }
The actual firmware is a bit more scattered since timing ends up being really important; in particular, the model calculations are broken into several pieces with LED updates in between to prevent flicker. If you want to see actual code... read on.
The complete v07 (again, more on that later!) firmware is here. I'll get it up on GitHub once I consider it "release-worthy".. I still need to debug a few timing issues with the 'scope. But feel free to check it out if you like. Below, I'll go over the non-commented portions, skipping the exhaustive intro that covers hardware and Izhikevich model outputs.
Global Variables
/* Izhikevich model parameters and coefficients */
const int16_t a = 5;
const int16_t b = 2;
const int16_t c = -65;
const int16_t d = 8;
const int16_t E = 6;
const int16_t F = 2;
const int16_t G = 16;
const int16_t H = 161;
These are the parameters (a, b, c, d) and coefficients (E, F, G, H) that feed the membrane potential calculation model. Much more info on their derivation can be found in the previous update. I kept 'em in one spot so they're easy to change if I find better values. Note that these are all 16-bit signed integers, so maintaining atomicity will be a requirement for avoiding weird errors./* Izhikevich model variables */
volatile int8_t I;
volatile int8_t I_rest = 21;
volatile int16_t v = -65;
volatile int16_t u = 0;
These are the Izhikevich values that change every 'tick'. I gets set to I_rest at the beginning of the cycle before getting reset to an appropriate number based on dendrite states. v and u are the all-important membrane voltage and membrane recovery values./* Intra-model variables */
volatile int16_t vSq = 0;
volatile int16_t vF = 0;
volatile uint8_t modelStage = 0;
volatile int16_t v_prev;
volatile int16_t u_prev;
Here's where stuff gets a little bit more interesting. One of the more computationally expensive operations required in implementing the Izhikevich model involves squaring the current value of v. I ended up breaking this, along with a few other parts, out of the main calculation to save time. The modelStage variable keeps track of where the model currently is in this process.
/* Neuron variables */
volatile uint8_t firing = 0;
volatile uint8_t fireTimer = 0;
const uint8_t axonPulseLength = 5;
volatile unsigned char dendStatus = 0; //current status of four dendrites, including types
volatile unsigned char dendStatusPrev = 0; //previous dendrite status/type
volatile int8_t val_Dend[4]; //keeps track of current dendrite's contribution to I (positive or negative)
volatile uint8_t stg_Dend[4] = {0,0,0,0}; //current stage of each dendrite impulse: 0 is REST, 1 is HOLD, 2 is DECAY
const int8_t hldTime_Dend[4] = {20,20,20,20};
volatile int8_t hldTimeCur_Dend[4];
const int8_t hldVal_Dend[4] = {10,10,10,10};
const int8_t dec_Dend[4] = {2,2,2,2};
These are variables related to the state of the neuron, its inputs, and its outputs. firing toggles to 1 if the neuron is experiencing an action potential; once this happens, fireTimer increments until it hits axonPulseLength to ensure the output signals are long enough to trigger downstream NeuroBytes. The remaining variables and arrays keep track of the individual dendrites' contributions to I, and handle the hold and decay functions that make input signals semi-persistent./* LED variables */
volatile uint8_t LED[3] = {0,0,0}; //R,G,B, 0-100
volatile uint8_t LEDtick = 0; //0-100
volatile uint8_t LEDfade[3][61] = {//fader for -102 <= v < -41, where I=21 (v=-83) is rest (pure green). R,G,B
{0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,1 ,1 ,2 ,2 ,3 ,3 ,4 ,4 ,5 ,5 ,6 ,6 ,7 ,7 ,8 ,8 ,9 ,9 ,10,10,11,11,12,12,13,13,14,14,15,15,16,16,17,17,18,18,19,19,20},
{1 ,2 ,3 ,4 ,5 ,6 ,7 ,8 ,9 ,10,11,12,13,14,15,16,17,18,19,20,20,19,19,18,18,17,17,16,16,15,15,14,14,13,13,12,12,11,11,10,10,9 ,9 ,8 ,8 ,7 ,7 ,6 ,6 ,5 ,5 ,4 ,4 ,3 ,3 ,2 ,2 ,1 ,1 ,0 ,0 },
{19,18,17,16,15,14,13,12,11,10,9 ,8 ,7 ,6 ,5 ,4 ,3 ,2 ,1 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 ,0 }
These variables keep track of the current LED state and PWM "tick". The massive LEDfade[][] array is used as a cross-reference to determine appropriate R, G, and B values for each given v value; this gives me more flexibility than the v04 firmware (which used linear interpolation) if I want to tweak the colors a bit. You can see that I set the maximum LED brightness at 20%, which seemed about right during testing next to v04 boards./* Timing variables */
volatile uint8_t tick = 0; //ISR flips this to non-zero to update loop
const uint8_t modelUpdateFrequency = 255; //how many ticks pass before the model recalculates (higher = slower)
const uint8_t modelUpdateMultiplier = 3; //multiplier for modelUpdateFrequency (since they're 8-bit unsigned integers)
Last set of global variables. These values are used for timing; when the timer interrupt service routine flips tick to a non-zero value, the program updates. modelUpdateFrequency and modelUpdateMultiplier are used to scale the speed of the neuron simulation; as you can see, I needed 765 (3 * 255) ticks to roughly match the v04 update rate. Yes, this means that NeuroBytes v07 can be used as a real-time biological neuron simulator which is extremely awesome.Functions
void getDendrites(void) {
/* updates dendStatus to the current input value:
bit MSB 6 5 4 3 2 1 LSB
DEND 4 3 2 1 4 3 2 1
input SIG SIG SIG SIG TYPE TYPE TYPE TYPE
pin PB1 PB0 PB7 PD6 PB2 PD7 PB6 PD5
dendStatusPrev = dendStatus;
dendStatus = 0;
dendStatus |= ((PINB & (1<<PB1))<<6);
dendStatus |= ((PINB & (1<<PB0))<<6);
dendStatus |= ((PINB & (1<<PB7))>>2);
dendStatus |= ((PIND & (1<<PD6))>>2);
dendStatus |= ((PINB & (1<<PB2))<<1);
dendStatus |= ((PIND & (1<<PD7))>>5);
dendStatus |= ((PINB & (1<<PB6))>>5);
dendStatus |= ((PIND & (1<<PD5))>>5);
getDendrites() works with a global 8-bit char called dendStatus, where the four least significant bits represent the four dendrite types (inhibitory or excitatory) and the four most significant bits represent the four dendrite statuses (high or low). I'll get into dendrite types more when I go over hardware--suffice it to say that each connector has four conductors (ground, power, type, signal) allowing upstream NeuroBytes and input modules to decide whether stimulus causes excitation or inhibition.
After saving the previous dendrite state into dendStatusPrev, the eight similar looking expressions use bitshift masks (such as 1<<PB7) to check various input pin states, then a further bitshift operation to store that state in the appropriate dendStatus bit. For example, the signal state of dendrite 3 is found in PB7 (i.e. Port B's MSB) but needs to be recorded in bit 5 of dendStatus; thus, the masked port read is shifted right two bits before getting incorporated into dendStatus.
void calcDend(uint8_t dend) {
/* checks the dendrites and updates I based on hold and decay variables. function only runs on the
dendrite indicated in the argument so it can be staged via updateModel(). */
uint8_t inh = 1; //toggles to 0 if the selected dendrite is excitatory
if (dendStatus & (1<<dend)) {
inh = 0;
switch (stg_Dend[dend]) {
case 0: //REST
val_Dend[dend] = 0;
if (dendStatus & (1<<(dend + 4))) {
stg_Dend[dend]++;
break;
case 1: //HOLD
val_Dend[dend] = hldVal_Dend[dend];
hldTimeCur_Dend[dend] = hldTime_Dend[dend];
else {
hldTimeCur_Dend[dend] -= 1;
if (hldTimeCur_Dend[dend] == 0) {
stg_Dend[dend]++;
break;
case 2: //DECAY
stg_Dend[dend]--;
else {
if ((val_Dend[dend] - dec_Dend[dend]) > 0) {
val_Dend[dend] -= dec_Dend[dend];
else {
stg_Dend[dend] = 0;
break;
if (inh == 1) {
val_Dend[dend] = -val_Dend[dend];
calcDend(dend) is one of the few functions that takes an argument; in this case, you feed it the dendrite number (0, 1, 2, or 3 for 1, 2, 3, or 4.. ugh) and it only looks at that input. I haven't timed this function yet, but I did this anticipating the need to stage the function between LED update cycles.This function first checks to see if the currently selected dendrite is inhibitory or excitatory; if the latter, it sets the local variable inh to 0. After that, the function checks the stg_Dend array to see whether that dendrite is currently zero (i.e. contributing nothing to I), holding, or decaying. If the dendrite is stimulated, the stage is reset to HOLD and the appropriate timers are reset. Finally, the resultant value stored in the val_Dend array is negated if the input is inhibitory.
void calcI(void) {
/* updates I based on current dendrite values */
uint8_t i;
I = I_rest;
for (i=0;i<4;i++) {
I += val_Dend[i];
Sums the four dendrite contributions to update I as needed. Starts at the resting point for I, which is 21 in this particular version.void updateModel(stage) {
/* This function updates the membrane potential (v) and recovery potential (u) variables based on the
current I value. Since the Izhikevich model includes a reset check to determine firing, this function
also updates the 'firing' variable to 1 when the neuron fires. The model uses 16-bit integer math, so
interrupts are temporarily disabled to maintain atomicity.
Execution time: 29.0 us max, depending on current stage. */
uint8_t temp = SREG;
cli();
if (stage == 0) {
getDendrites();
else if ((stage >= 1) & (stage < 5)) {
calcDend(stage - 1);
else if (stage == 5) {
calcI();
else if (stage == 6) { //17.4 us
vSq = square(v);
else if (stage == 7) {
v_prev = v;
u_prev = u;
vF = v * F;
else if (stage == 8) { //29.0 us
if(v_prev > H) {
v = c;
u = u_prev + d;
firing = 1;
else {
v = v_prev + (vSq >> E) + vF + G - u_prev + I;
u = u_prev + (((v_prev >> b) - u_prev) >> a);
firing = 0;
else if (stage == 9) { //28.9 us
translateColor();
SREG = temp;
This function stages various calculations through ten steps, each of which resolves in less than the time between LED update cycles (40 us). First, the function stores the current interrupt register into temp and disables global interrupts; this is used to maintain atomicity, as some of the math uses 16-bit integers. Next, the function does different things depending on the stage:Stage 0: update the current dendrite status using getDendrites().
Stage 1, 2, 3, 4: calculate the four dendrite contributions to I using calcDendrites(dend).
Stage 5: sums the four dendrite contributions to update I using calcI().
Stage 6: starts the Izhikevich calculations by squaring the membrane potential, v, and storing the result in vSq. The square(int) function also checks for 16-bit signed integer overflow, and if present, instead returns 32767.
Stage 7: continues the Izhikevich calculations by multiplying v by F, and storing the result in vF. Also stores the current values of v and u since both of the next calculations need to run with each variable.
Stage 8: finish the Izhikevich calculations by checking for a fire state (v > H) and either resetting the model or finishing the calculation of v and u. Note, again, that E, a, and b have been replaced with right bit-shifts (i.e. 1/n^2).
Stage 9: translate the current membrane potential value into LED values (shown below).
Finally, the interrupt register is restored to its previous value. Note that when Stage > 9, this function doesn't do anything.
void translateColor() {
/* translates membrane potential (v) values into the RGB array
resting membrane potential:
v < -102 pure blue
-102 <= v < -90 fade blue to green
v = -90 pure green
-90 < v =< -71 fade green to red
v > -71 firing (pure white)
Execution time: 28.9 us
if(v < -102) { //3.5 us
LED[0] = 0;
LED[1] = 1;
LED[2] = 20;
else if((v >= -102) & (v < -41)) { //24.1 us
LED[0] = LEDfade[0][(uint8_t)(v + 102)];
LED[1] = LEDfade[1][(uint8_t)(v + 102)];
LED[2] = LEDfade[2][(uint8_t)(v + 102)];
else {
LED[0] = 20;
LED[1] = 1;
LED[2] = 0;
This function checks the current membrane potential value and translates that into R, G, and B LED values using the massive LEDfade[][] array. Note that the green LED is always at least equal to 1, as shutting it off entirely (especially during hyperpolarization) is quite noticeable to the eye.void updateLED(void) {
/* Updates the RGB LED based on the current membrane potential value. Uses PWM fading and global variables to
figure out when the various elements should be on. Resolution controlled by LEDtick reset.
Execution time: 5.6 us */
if(LED[0] > LEDtick) {
PORTC &= ~(1<<PC3);
else {
PORTC |= (1<<PC3);
if(LED[1] > LEDtick) {
PORTC &= ~(1<<PC4);
else {
PORTC |= (1<<PC4);
if(LED[2] > LEDtick) {
PORTC &= ~(1<<PC2);
else {
PORTC |= (1<<PC2);
LEDtick++;
if (LEDtick > 100) {
LEDtick = 0;
Pretty simple one that executes quite fast (and quite often). Checks the global LEDtick variable and extinguishes the LEDs when it exceeds their setpoints. Also resets LEDtick at 100 cycles (well, 101 cycles...).ISR(TIMER0_COMPA_vect) {
/* Makes ticks fire at a regular interval in the main loop. */
tick = 1;
Everyone says to keep these really brief, so the timer interrupt service routine just changes a single variable.void systemInit(void) {
/* set up D1 */
DDRC |= ((1<<PC2) | (1<<PC3) | (1<<PC4));
PORTC |= ((1<<PC2) | (1<<PC3) | (1<<PC4)); //set pins = LED off
/* set up dendrites */
DDRB &= ~((1<<PB7) | (1<<PB0) | (1<<PB1) | (1<<PB6) | (1<<PB2));
DDRD &= ~((1<<PD5) | (1<<PD6) | (1<<PD7));
/* set up axons */
DDRD |= (1<<PD0);
DDRC |= ((1<<PC1) | (1<<PC0) | (1<<PC5));
PORTC |= ((1<<PC0) | (1<<PC5)); //set type pins
/* set up Timer/Counter0 */
TCCR0A |= ((1<<CTC0) | (1<<CS00) | (1<<CS01)); //CTC, clk/64
TCNT0 = 0;
OCR0A = 4; //loop time = 8 * (OCR0A + 1) uS
TIMSK0 |= (1<<OCIE0A); //enables Output Compare Match A ISR
/* misc */
sei(); //enable global interrupts
Mostly self-explanatory with comments. Sets all the registers--inputs, outputs, timer, interrupts, etc. Tick timing is controlled by the Timer/Counter0 Output Compare Match A register, OCR0A; as shown in comments, each tick duration is approximately 8 * (OCR0A + 1) microseconds. void fire(void) {
PORTC &= ~((1<<PC2) | (1<<PC3) | (1<<PC4));
fireTimer = axonPulseLength;
Makes the LED flash WHITE when the NeuroBytes board fires. Also resets the fireTimer to hold axon outputs HIGH for axonPulseLength ticks.Main Loop
int main(void) {
systemInit();
uint8_t i = 0; //counters for update delay
uint8_t j = 0;
for(;;) {
while(tick == 0) { /* idle loop */ }
/* This stuff happens every 40 uS or so */
tick = 0;
if (i < 10) {
updateModel(i);
if (firing == 0) {
updateLED(); //5.6 us
else {
fire();
j++;
if (j == modelUpdateMultiplier) {
i++;
j = 0;
if (i == modelUpdateFrequency) {
i = 0;
if (fireTimer > 0) {
PORTD |= (1<<PD0);
PORTC |= (1<<PC1);
fireTimer--;
else {
PORTD &= ~(1<<PD0);
PORTC &= ~(1<<PC1);
This loop ties everything together. The main loop uses modelUpdateMultiplier and modelUpdateFrequency in conjunction with i and j, two local counter variables, to run updateModel() and iterate fireTimer when needed. Note the use of a while loop to take up all the tick slack; during testing, I can easily comment this line out, add in a debug pulse on an extra I/O line, and use my oscilloscope to quickly figure out the execution time for each stage.
And here it is running on a pair of teeny v07 boards:
I'll get back to hardware next. Comments on the code are welcome!
