The battery tester has been ran with the 5V regulator feeding the relay board. The UNO's voltage now locks in and does not fluctuate with the changing states of the relays. Here is an excerpt from the run:
Program Run | 0 | 1240 | -2 | 11001 | 4962 |
Program Run | 5 | 1069 | 335 | 11101 | 4940 |
Program Run | 10 | 1058 | 392 | 11101 | 4940 |
Program Run | 15 | 1058 | 389 | 11101 | 4940 |
Program Run | 20 | 1058 | 387 | 11101 | 4940 |
Program Run | 25 | 1056 | 386 | 11101 | 4940 |
Program Run | 30 | 1053 | 384 | 1111101 | 4940 |
Program End | 35 | 1048 | 397 | 0 | 4940 |
This test and the prior versions test can be found on github.
