Well removed it from the housing. Going to take some pictures. I applied 5v from 4 AA batteries to the voltage pin. However nothing happened currently reading up on how others have connected an RGB scanner light up but the pictures are minimal to say the least not sure where to connect the ground. Pictures in a second.
Also nothing helpful or remarkable underneath the board.
