Sound Recorder
Recorder , audio player and more...
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
The project consists of a recorder/player that can record a sound message of approximately 12 seconds.
The device is divided into two blocks both based on a ChipCorder ISD1212 :
-a main device can record an audio message from a microphone and play from a speaker.
-a secondary device able to copy the message contained in the main device.
The device is thus not only a simple recorder/player, but allows you to broadcast the recorded message to a second minimal registration, to be used in others projects.
https://mipstudioblog.wordpress.com
