An LED-throwie which only activates at dawn or night. Add a magnet and you can stick it at metallic surfaces.
Assemble according to circuit schematics (see pictures).
If you increase Rpullup, you reduce the base current, so you can save the Rled and reduce the battery drain during daytime. It depends on your transistor's current gain, you can also try with a 470K trimpot :-)
Now, what if you found a light-sensitive resistor with a reverse characteristic ? shorting the base to 0V is a wasteful strategy...
