The board didn't had a flash memory to store the FPGA configuration. The TI processor had to be removed to free the pins that are used to attach a flash memory to the FPGA. A Winbond 25Q16 was installed to store the bitstream. To upload the bitstream to flash I've used the fpgaprog command line tool and the FT2232.
![](https://cdn.hackaday.io/images/8002771535583471682.jpg)
![](https://cdn.hackaday.io/images/363621535583550078.jpg)
A piece of veroboard was glued near the edge connector to facilitate the access to the FPGA pins.
![](https://cdn.hackaday.io/images/7317801535583955690.jpg)
![](https://cdn.hackaday.io/images/1452511535584192842.jpg)
