Adding 3D Line to the ISR
Okay, it get complicated quickly but this is really only the beginning!
Simple 3 Axis ISR Motion Controller - Part 2: Add Motion Control
Written by Alan Cooper (agp.cooper@gmail.com)
This work is licensed under the
Creative Commons Attribution - NonCommercial 2.5 License.
This means you are free to copy and share the code (but not to sell it).
Motion is in absolute steps
Feed rate range is 1 to 4095 steps per second
// Motor controller (CNC board) pin mapping:
#define DirX 2
#define DirY 3
#define DirZ 4
#define StepX 5
#define StepY 6
#define StepZ 7
#define Enable 8 // Enable stepper motors (active low)
#define Laser 12 // Turn laser on or off
// Motion controller defaults
#define Feed 1000 // Default feed rate
#define xReverse false // Reverse X axis direction
#define yReverse true // Reverse Y axis direction
#define zReverse false // Reverse Z axis direction
// Motion controller and ISR variables
volatile int xNew; // The target X co-ordinate
volatile int yNew; // The target Y co-ordinate
volatile int zNew; // The target Z co-ordinate
volatile int feed; // Set motion feed rate
volatile int laser; // Laser (on/off)
volatile int xCurrent=0; // The current X co-ordinate
volatile int yCurrent=0; // The current Y co-ordinate
volatile int zCurrent=0; // The current Z co-ordinate
volatile int steps=-1; // Number of steps remaining in motion
ISR(TIMER2_OVF_vect)
static int dx,dy,dz;
static int ax,ay,az;
static int sx,sy,sz;
static int mx,my,mz;
static int stepX,stepY,stepZ;
static unsigned int phase=0;
static unsigned int magic=8000;
if (phase<0x8000) {
phase+=magic;
if (phase>=0x8000) {
if (steps==0) {
// Determine next movement parameters
dx=xNew-xCurrent;
dy=yNew-yCurrent;
dz=zNew-zCurrent;
ax=abs(dx);
ay=abs(dy);
az=abs(dz);
sx=xNew<xCurrent?-1:xNew>xCurrent?1:0;
sy=yNew<yCurrent?-1:yNew>yCurrent?1:0;
sz=zNew<zCurrent?-1:zNew>zCurrent?1:0;
if ((ax>=ay)&&(ax>=az)) {
mx=0;
my=ay-(ax>>1);
mz=az-(ax>>1);
steps=ax;
} else if ((ay>=ax)&&(ay>=az)) {
mx=ax-(ay>>1);
my=0;
mz=az-(ay>>1);
steps=ay;
} else {
mx=ax-(az>>1);
my=ay-(az>>1);
mz=0;
steps=az;
// Set the stepper directions
if (xReverse) {
digitalWrite(DirX,(1-sx)>>1);
} else {
digitalWrite(DirX,(sx+1)>>1);
if (yReverse) {
digitalWrite(DirY,(1-sy)>>1);
} else {
digitalWrite(DirY,(sy+1)>>1);
if (zReverse) {
digitalWrite(DirZ,(1-sz)>>1);
} else {
digitalWrite(DirZ,(sz+1)>>1);
// Set laser
if (laser>0) {
digitalWrite(Laser,HIGH);
} else {
digitalWrite(Laser,LOW);
// Set feed
magic=feed<<3;
// Reset step low
digitalWrite(StepX,LOW);
digitalWrite(StepY,LOW);
digitalWrite(StepZ,LOW);
} else {
phase+=magic;
if (phase<0x8000) {
if (steps>0) {
// Advance steppers (25us)
stepX=0;
stepY=0;
stepZ=0;
if (my>=0) {
my-=ax;
stepY=sy;
if (mz>=0) {
mz-=ax;
stepZ=sz;
my+=ay;
mz+=az;
stepX=sx;
if (mx>=0) {
mx-=ay;
stepX=sx;
if (mz>=0) {
mz-=ay;
stepZ=sz;
mx+=ax;
mz+=az;
stepY=sy;
} else {
if (mx>=0) {
mx-=az;
stepX=sx;
if (my>=0) {
my-=az;
stepY=sy;
mx+=ax;
my+=ay;
stepZ=sz;
xCurrent+=stepX;
yCurrent+=stepY;
zCurrent+=stepZ;
// Step HIGH
if (stepX!=0) digitalWrite(StepX,HIGH);
if (stepY!=0) digitalWrite(StepY,HIGH);
if (stepZ!=0) digitalWrite(StepZ,HIGH);
steps--;
// Set steps to indicate new motion not set
if (steps==0) steps=-1;
int iSin[360];
void setup()
// LED
pinMode(LED_BUILTIN,OUTPUT);
// Initialise Motor Controller Hardware
pinMode(DirX,OUTPUT);
pinMode(StepX,OUTPUT);
pinMode(DirY,OUTPUT);
pinMode(StepY,OUTPUT);
pinMode(DirZ,OUTPUT);
pinMode(StepZ,OUTPUT);
pinMode(Enable,OUTPUT);
pinMode(Laser,OUTPUT);
digitalWrite(DirX,LOW);
digitalWrite(DirY,LOW);
digitalWrite(DirZ,LOW);
digitalWrite(Enable,LOW); // Active low
digitalWrite(Laser,LOW); // Active high
// Use Timer 2 for ISR
// Good for ATmega48A/PA/88A/PA/168A/PA/328/P
cli();
TIMSK2=0; // Clear timer interrupts
TCCR2A=(0<<COM2A0)|(0<<COM2B0)|(3<<WGM20); // Fast PWM
TCCR2B=(1<<WGM22)|(2<<CS20); // 2 MHz clock and Mode 7
OCR2A=243; // Set for 8197 Hz
OCR2B=121; // Not used
TIMSK2=(1<<TOIE2)|(0<<OCIE2A)|(0<<OCIE2B); // Set interrupts (on Top Overflow)
sei();
// Prepare circle array
for (int i=0;i<360;i++) {
iSin[i]=(int)(200*sin(radians(i)));
// Give some time for mechanical set up
delay(5000);
void loop()
/* Motion Command */
// Used to keep track of motion
static int sinAngle=-1;
static int cosAngle=0;
// if last motion complete
if (steps==-1) {
if (sinAngle==-1) {
sinAngle=0;
cosAngle=90;
cli();
xNew=iSin[cosAngle];
yNew=iSin[sinAngle];
zNew=0;
feed=1000;
laser=0; // Laser off
sei();
} else if (sinAngle==-2) {
cli();
xNew=0;
yNew=0;
zNew=0;
feed=1000;
sei();
} else {
sinAngle+=1;
cosAngle+=1;
if (sinAngle>=360) sinAngle-=360;
if (cosAngle>=360) cosAngle-=360;
cli();
zNew=0;
feed=1000;
laser=1; // Laser on
sei();
if (sinAngle==0) sinAngle=-2;
// Set steps to indicate a new motion has been set
steps=0;
This code is a variation of the Turret Scanner but simplified a little. I have also used another variation on my Laser CNC machine (with the pin mappings adjusted for the Laser board) testing different feed rates:
As you can see it works okay.
Note the gap at the top of the circle for the faster feed rates (lighter burns). They are not due to a code error. It is just that lasers need time to start a burn but less time to maintain a burn.
AlanX
agp.cooper
