Raspberry Pi Hi8 Cassette Case
A Poor man's Raspberry Pi case from an old Sony Hi8 Cassette Case.
Just needed something to keep the grub from my son off of the board and came up with this in a pinch. This is for a Model A, so the larger size fit into the Hi8 case well. Also a slight trim in the top for the USB ports and trimmed a few leads on the bottom as well. All that was required was a Dremel with a cutting and grinding bit (To grind the holes, don't use a drill, the plastic is fragile.) Not too pretty but works in a pinch and the case swings open just like a cassette case for easy access.
  • 1 × Sony Hi8 Cassette Case
Rich text editor
