You can solder a small tactile button directly to the Trinket from 3V (or 5V) to Pin 1 and the LED circuit will act as a pull down. Helpful for reducing wiring in a simple and quick project like this one. Inspiration from here (see bullet 2): https://learn.adafruit.com/tap-tempo-trinket/things-learned
dhgoldberg
