Git, Casing update, custom PCB
A project log for UV Exposure Unit
UV Exposure Unit reproducable in every Hackerspace with a Laser-Cutter.
alex365Alex365 • 11/26/2014 at 17:13•0 Comments
While my initial goal was to create a UV Exposure Unit to produce a custom PCB for a beamer, which I have achieved, it's now time to make the entire unit available for everyone.
I have set up a Git repository for the project. I will upload the .dxf files for the casing and the code, that I've already uploaded here.
Furthermore I'm planning to create a custom PCB for the UV Exposure Unit. While a Arduino is quite nice, a custom PCB saves space inside the box and makes it more compact.
EDIT: DXF-Files uploaded. I'm still searching for a proper license for the project...
