The seven segment Python display library needed some cleaning up - the indicator lights on the display were either all on or all off. The ClockDisplay library now will set each of the four indicators individually, so the app running the clock logic should be much more simple.
The actual time display is running fine now, moving on to audio output. After "alarm clock" functionality is created by piping audio out at a specified time, I'll work on the enclosure.
