So the thingy that will have the outputs of a BCD to DEC converter and the 28V power supply fed in and put out the high voltage when switched by the BCD to DEC has been optimised from the one used in http://web.jfet.org/inGrid/ to my specs - higher current, lower voltages. See the Yenka simulation schematic snaps:
Emil J
