At the moment the hardware only exists as a test-setup and the software is a work in progress. I regularly derive little spinoff projects and recently focussed on capturing the still images as good as possible. By grandfather and my dad were both avid photographers and there is quite an archive to transfer into the digital age.
The software is built from scratch using scanimage and python for capturing and imagemagick and GNU-octave for frame detection, extraction and processing. The resulting frames are finally put together using ffmpeg. Since the prototype transport system is quite sloppy (it's built out of Fischertechnik parts), I have significant horizontal movement of the images but the system works well. I just have to find the time to draw final parts and send them off to the laser cutter...
treibair
Hi there, your project sounds nice !
BTW it would be great to establish some kind of collaboration (for the software part, maybe) with other related DIY projects:
https://hackaday.io/list/175104-diy-film-scanners
Hope that helps/inspires.
