Here's a pic of the machine as it stands today:
There are some upgrades and repairs - belt drive being the most important, then things like:
- 1/4" aluminum bed.
- Heavy duty bed heater.
- Buildtak style build surface.
- EZstruder extruder upgrade, with burly motor.
- After several tries, settled on the E3D V6 hot end.
- Designed and printed cooling nozzles for hot end fans.
- 2020 extrusion to replace cracked/destroyed acrylic top deck.
- Printed brackets to hold extruder cooling fan, wiring combs, and filament holder.
Details of the printed stuff will be in subsequent log files.
