This circuit board can control servos and digital outputs with a PS4 controller over USB and Bluetooth. Also works with a gaming joystick and several 3D mice. No programming is required, it comes pre-programmed and it has most of the servo adjustments you'd ever need to make already built in. You can hold the "PS" and "Share" buttons for 3 seconds to enter a configuration mode, and cycle through the output channels and make adjustments using the controller buttons.
Servo Adjustments include:
- Trim
- Sensitivity
- Travel direction
- Travel limits
- Deadband
- Center calibration
- Incremental Mode (servo moves incrementally in the direction you push the stick)
Button Adjustments include:
- Toggle
- Autofire (pulse with and frequency adjustable)
- Single pulse (pulse width adjustable)
- Toggled autofire
- Output inversion
It takes 5-16V, and has an on-board 5V regulator than can be used to power the servos, or you can bypass it to power the servos directly from the power supply if you need more power.
Adam L. Humphreys
Paras Mahajan
