There are people building HD6309 SBC, which is great to hear! I've received a couple of questions regarding construction that I will address in a couple new project logs:
FT230XS Configuration
A "fresh" FT230XS device will enumerate as a VCP, but needs a tiny bit of tweaking in order to operate as intended on the SBC PCB:
The FT_PROG configuration tool is available from FTDI here. On the same page is the FT_PROG user guide. Connect the USB, start FT_PROG, and use the "Scan & Parse" option to find the FT230XS device. Afterwards, the configuration can be edited:
In the USB Config Descriptor section, set the following.
bmAttributes = Self Powered
MaxPower = 500mA
In the Hardware Specific section, set the following:
CBUS Signals
C0 = VBUS_Sense
C1 = TX&RXLED
C2 = Drive_0
C3 = Drive_0
IO Pins
CBUS Drive = 8mA
