Let's start =)
A project log for LETL trigger
Handy Long Exposure (LE) and Time Lapse (TL) photography trigger with trinket.
kamermankamerman 12/01/2014 at 23:220 Comments
Let's see what did i start with? Well technically I started with submitting project on hackaday so this is the next thing i did. Since I am waiting for my trinket pro I started with designing user interface.
I believe that user interface is of the most important things that make a product desirable. There will probably be a lot of different designs along the way but you have to start somewhere. User will have 4 buttons to navigate - increase, decrease, back, next. There will be a few different modes to use. I am thinking of having 2 different modes for long exposure and 2 for time lapse.
Long exposure mode one will be fairly simple. You will simply input the time you want the shutter to stay open. The problem with this mode is that you will have to manually calculate how much time you need shutter to stay open.
Long exposure mode two will be a little more helpful. In this mode you will enter shutter speed that is shown on your camera. Then you will enter in the "stop" value of your ND filter (for achieving longer exposures we use ND filters). For example if your camera shutter speed without filter is 1/15 s and you have a 10 stop filter the correct exposure will be 60 seconds long. So instead of manual calculating (like mode one) all the calculating will be done by trigger.
Time lapse modes are a little more complicated. There are few parameters in shooting time lapse. We need to know how may photographs we want. We determine that by how long our final video need to be and by frame rate it will be played. So the equation looks like this.
\color{White} \large \color{White} \large number\ of\ photos = video\ time * video\ fps
Now we know how many photos we need. We just need to know how fast do we shoot them. For example maybe 1 photo per 4 seconds. That is determined with how long we want to shoot. We got one more equation coming up.
\color{White} \large \color{White} \large number\ of\ photos = real\ time * photo\ fps
For example we want to make a 10 second video clip from 20 minutes scene. Our video will be played with 24 fps. With that we calculate that we need 240 photos and we need to shoot them 0.2 fps (one frame every 5 seconds). Okay enough math. As you can see there are a lot of different possibility for which parameters to input. Two most logical to me are described next.
Time lapse mode one will not demand the knowledge how time lapse work. You will simply insert your target video time (video fps will be fixed at 24 fps) and for how long you want to photograph.
Time lapse mode two will accept number of photos you want and the duration you want to shoot. There maybe additional mode with number of photos and photo fps for input.
That's pretty much it for now =).
PS. If you really read all that here is a long exposure photo for you to enjoy =)
