Main parts involved
high level software design.
Found an old phone to use as a case which had some small dremel work done to open up the back more as well as remove some bracing that was in the way. It is rather big but I might be able to re-purpose the keypad for input.
Connecting all parts together
Cram it all into the phone. I used some think plastic to keep metal parts from touching on the components.
Jakob Kilian
Eric Moyer
Benjamin Broce
Mike
Reusing the cellphone is a good idea. That enclosure is meant to handle being carried around in your pocket... I have a half dozen old phone sitting in a box somewhere around here ;-)
