The PCB is fixed
I fixed the PCB layout from the previous post, it seems to work well enough.
What is tested and working:
- LCD + Touch
- SDIO connceted SD card
- Power + charging
- Speaker
- Buttons
- Onboard FTDI
Not tested:
- Internal and external expansion ports.
Known bugs:
Vcc is used as voltage reference, so when the battery goes under 3.3V it measures battery voltage incorrectly. The device works until about 2.7 V (battery voltage) and then it became a bit buggy and occasionally crashes filesystem on the SD card. If you keep the device charged, then you don't experience these bugs, but I wil be fixing them in a next board revision anyway.
Known bugs will be posted or removed from readme file in the hw repo.
Where to get the KiCad files & gerbers?
On the SDA Hardware GitHub
Update on the case
I also updated the case and printed it in black (I run out of red filament). You can get the .stl files and the FreeCAD project on the SDA Hardware GitHub.
brtnst
