In order to nicely mount the NRF24L01+ breakout board I did a mod to one of the solderless breadboards. I removed four of the connector strips and cut them in half with my dremmel.
I used some hookup wire insulation to insulate the broken apart connectors on two of them. I didn't bother with the last two. I found that if you put too long of a piece of insulating material the spring connecters don't work very well, better just to leave an air gap.
Here's a pic with only the wires.
