Here is the code:
/* Networking Group Timer Created by: Chad Lawson <chad@origamirocket.com> Version: 1.0 */ // Assign the LEDs to pins #define RED 6 #define GREEN 5 #define BLUE 3 #define TILT 8 // Assign times to the colors #define gTime 60 #define yTime 90 #define rTime 120 #define BOUNCE 60 // Since we are using a CA LED we need to work backwards #define COMMON_ANODE // Define our variables long start; boolean running = true; boolean tiltState; int bounceCheck = 0; void setup() { pinMode(RED, OUTPUT); pinMode(GREEN, OUTPUT); pinMode(BLUE, OUTPUT); pinMode(TILT, INPUT); // Initialize our timer setColor(0,0,0); start = millis(); // Let's try it Serial.begin(9600); Serial.println("Let's go!"); } // setup void loop() { tiltState = digitalRead(TILT); if(tiltState == LOW) { Serial.print("Tilt!: "); if(bounceCheck > BOUNCE) { running = false; } else { bounceCheck++; } Serial.println(bounceCheck); } else { if(bounceCheck > 0) { bounceCheck--; } } if(running == true) { int secs = getTime(); switch(secs) { case 0: setColor(4,4,4); break; case gTime: setColor(0,255,0); break; case yTime: setColor(128,255,0); break; case rTime: setColor(255,0,0); break; } // switch } // if(running) else { setColor(128,0,128); start = millis(); running = true; } // else } // loop int getTime() { long delta = millis() - start; int secs = delta / 1000; return secs; } void setColor(int red, int green, int blue) { #ifdef COMMON_ANODE red = 255 - red; green = 255 - green; blue = 255 - blue; #endif analogWrite(RED, red); analogWrite(GREEN, green); analogWrite(BLUE, blue); } /* Version History 1.0 - Initial Version (141220) */
