NEW VERSION (Now OwnWatch instead of Tardis-Watch):
Not just a new name, check out what else changed:
- Supports Bluetooth 4.0 AND 2.0 (HM-13 Dual mode Bluetooth module)
- Gyro + Accelerometer (MPU6050)
- Magnetometer (HMC5883L)
- Pressure Sensor (BMP180)
- Three Temperature Sensors
- Ambient Light Sensor
- Audio (via internal Speaker or external Headphones)
- Lithium-Polymer Battery (280mAh)
- Atmel ARM Cortex-M0+ SAM D21 - 48MHz - 256KB Flash - 32KB RAM
- New Case-Design (54mm * 40mm * 13.8mm)
OLD Versions
Of course the Tardis Watch brings all the features, you allready know from 'common brand watches' and you don't want to miss:
- Bluetooth 4.0 (fully compatible with the HM10 and the cheaper HC05 Bluetooth 2.0 module)
- USB 2.0 (microUSB)
- 1.44" TFT color display with a resolution of 128*128 (ST7735)
- Gyro + Accelerometer (MPU6050) + Magnetometer (MPU9150)
- Realtime Clock (DS3231)
- Lithium-Polymer battery (with 135mAh¹ or 240mAh²)
- Controller: Atmel AVR ATMega32U4 - 16MHz
- MicroSD Card slot (up to 8GB)
- Internal Speaker
- Two Temperature sensors
- Two Tactile switches for the navigation through the User Interface + one Home/Reset button
- Power Switch
- Two indicator LED's on the frontside (free programmable)
- Not much bigger than common Smartwatches (56mm * 40mm * 13.5mm¹-14.5mm²)
- Phoenex compatible GPIO connector for the IO Pins, so it's possible to easely connect your development boards, own projects or common Arduino Shields via a board adapter to the watch. (I adopted this system/idea from the great Phoenard)
Moritz Wenzel
Victor Dedios
WΛLLTΞCH
Ultimate Robotics
Timothy Woo
Hi. I'd like the full assembled device to study it seriously! My mail : se-b-81@live.fr. Anyway, thanks.
