First Prototype (V0.99) is finally completed after the USB connectors arrived here a little late.
There is also a yellow "Receive / RX" LED on the Right side of the microUSB Connector.
A project log for OwnWatch
The OwnWatch is a Arduino compatible smartwatch which is soft- and hardware expandable and not much bigger than a common brand smartwatch
