Got the cold toner transfer to acrylic working well. Transferred cut marks and decals to 3mm acrylic sheet. Cut layers out by hand and glued up the case. Sloppy application of the acrylic solvent messed up the logo a bit.
A project log for Clear enclosure project box legends
Not a project per se but a technique for enclosure fabrication.
