Since my last update - a mere 18 hours ago - a lot has happened (little of which was sleep, but that's ok, it's the weekend!!)
First up I started by soldering wires to the switches, the 9v battery snap and the socket for the LCD screen.
Work on the box started next. Using an Acrylic glue, I assembled the front and sides.
Aw! Looks like a robot!!
To close the box up, I've attached 4 screw tabs at the back.
These are threaded for an M3 screw. I'm using M3 screws throughout this build as they're a good size and I have a bunch of them in different lengths :)
Next up, final assembly!
