I uploaded the assembler and emulator source code to github. Try it out and let me know if it works for you. I omitted a build script as its only one .cpp file for each. The code was written and tested on windows, but as a simple console app it should work on any platform with little modification.
Try it out: https://github.com/JohnSully/Trinity
A disclaimer on the code: I wrote this quickly over the weekend and hacked it mercilsy to try new stuff. Its not the cleanest code but it works.
I also took some time to modify the jump instructions. JAF has now been replaced with JEQ, JEZ, and JMP. The new "ABC" program is much simpler:
; Outputs A,B,...,Z in a continuous loop
;Setup
Start:
LIM '@' ; 'A'-1
Loop: SWP
LIM 1
ADD
OUT
;Check if done
SWP
LIM 'Z'
SWP
JEQ Done
JMP Loop
Done:
JMP Start
And assembled:
000000: 00+--+ 0+-+0+ ;LIM 0+-+0+
0000+-: 00+--0 ;SWP
0000+0: 00+--+ 00000+ ;LIM 00000+
000+--: 0000+- ;ADD
000+-0: 00+-00 ;OUT
000+-+: 00+--0 ;SWP
000+0-: 00+--+ 0+0+00 ;LIM 0+0+00
000+0+: 00+--0 ;SWP
000++-: 000+-- 0000+- ;JEQ Done[0]:(0000+-)
000+++: 000+-+ 000--- ;JMP Loop[0]:(000---)
00+--0: 000+-+ 00-+0+ ;JMP Start[0]:(00-+0+)
