We created ESP8266 relay switch example. Sources for ESP8266 WiFi relay switch example can be found on GitHub. Tutorial how to build ESP8266 WiFi relay switch is also available.
A project log for ESP8266 EasyIoT Arduino library
With ESP8266 EasyIoT library making WiFi sensors is easy. Create WiFi Arduino sensor with couple lines of code.
