Hackaday.io Hackaday.io
Sign up Log in
DMX Lights for Artemis Spaceship Bridge Simulator
DIY bridge lights for the Artemis Spaceship Bridge Simulator
ethandicksethan.dicks
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
3.5k views
0 comments
2k followers
  • Description
  • Details
  • Files 0
  • Components 6
    • View all
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
3.5k
0
2k
6
Team (1)
  • ethandicksethan.dicks
Join this project's team
  • Basic build instructions and code
led arduino dmx artemis
Related lists
Litghts
Light
This project was created on 03/10/2014 and last updated 7 years ago.
Description
Since version 1.70, the Artemis Spaceship Bridge Simulator has supported ambient bridge lights under program event control using intelligent lights that use the DMX standard for communication. There are several options for plug-in-ready DMX lights, but it's also quite easy to put together an Arduino and three transistors to make your own Artemis-compatible bridge lights for less than half the cost of the commercial alternatives. All you really need is any AVR microcontroller with at least three PWM channels and an FTDI serial interface (like an Arduino Duemilenove)
Components
  • 1 × Arduino Duemilenove Must have FTDI chip, so Uno will not work as substitute
  • 3 × N-channel MOSFET TO-220 package Must be able to handle 2A @ 12V. Many parts are suitable.
  • 1 × Strip of common-anode 12V RGB LEDs Can be flexible ribbon or individual modules.
  • 1 × 12V power supply with 2.1mm barrel connector 2A will drive approximately 60 RGB LEDs
  • 1 × Arduino Prototype shield optional - provides place to mount MOSFETs
View all 6 components
Project Logs
Collapse
  • Artemis 2.1 has been Released!
    ethan.dicks • 06/13/2014 at 03:54 • 0 comments
    The new version of Artemis is here!    There are new DMX events to trigger on.  If you have 2.0, it's a free upgrade.
View project log
Log In/Sign up to comment
Sign up with Github
OR
Arduino Nano like baord but with the newer Atmega 328PB
Project Owner Contributor
Xduino Nano PB
alexAlex
All the simplicity of the Arduino Uno plus extra I2C UART SPI ADC IO and PWM channels. A development board for the new ATmega328PB MCU.
Prestissimo Uno+: Uno w/ more I2C UART SPI ADC IO
research-techResearch Tech
Use of an Arduino-type board, and an IR receiver and emitter to clone and emit signals
Infra Red Cloning With Arduino
rakaamburoRakaAmburo
Next Gen Arduino Mini Pro with Atmega328PB
*uino Mini Super (Atmega328PB)
andre-moehlAndre Moehl
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "DMX Lights for Artemis Spaceship Bridge Simulator", please tell us the reason.
Send message
Remove Member
