I've been working on improving serial communication between the Arduino and Python components. Previously, they just threw data at each other and hoped for the best. It now operates on a call and response model with a ~35Hz refresh rate. There's room for improvement if I reduce the API key lengths or compress the data somehow.
I also upped the baud from 9600 to 250000 to improve speeds.
I also improved the script to display some stats on exit:
$ ./arduino.py
Telemetry...Go
Arduino...Go
Calibration...Go
Fly by wire...Go
All stations are go.
Waiting for input:
{u'rcs': u'None'}
{u'action_group_1': u'None'}
{u'rcs': u'None'}
{u'rcs': u'None'}
{u'rcs': u'None'}
{u'rcs': u'None'}
^C
=======[ Stats ]=======
Updates: 465
Retransmits: 1
Percentage: 0.22%
Rate: 28.87ms
Frequency: 34.64Hz
Really pleased with out this came out. I had some misgivings for a bit when I was really in the weeds with this. I even started looking at alternatives like the Pi and Edison. I like the Edison a lot actually, but it doesn't have the pin density I'm looking for. Anyway, it's working great now. I can't wait to move on to the next big thing.
