My Raspberry Pi came yesterday, so went ahead and set that up. I had a few hiccups setting up KAPCOM, but it worked once I figured those out. I ended up needing some additional software packages:
sudo apt-get install python-pip
sudo apt-get install python-dev
sudo apt-get install python-xlibWith those installed, http://setup.py happily ran and installed the other Python modules. I also set up Synergy for sharing my trackball to my KSP machine. The instructions on Adafruit were mostly correct, but I also had to run the following commands:
sudo apt-get install libcurl4-openssl-dev
sudo unzip ext/gmock-1.6.0.zip -d ext/gmock-1.6.0/
sudo unzip ext/gtest-1.6.0.zip -d ext/gtest-1.6.0/After this, Synergy built correctly. I configured it so the mouse leaves the Raspberry Pi and never comes back unless you press F1:section: screens
KAPCOM-Pi:
Mac:
meta = alt
end
section: links
KAPCOM-Pi:
right(0,100) = Mac
left(0,100) = Mac
up(0,100) = Mac
down(0,100) = Mac
Mac:
# left(0,100) = KAPCOM-Pi
end
section: aliases
Mac:
Mac.local
KAPCOM-Pi:
KAPCOM-Pi.local
end
section: options
keystroke(F1) = switchToScreen(KAPCOM-Pi)
end
I also added a startup script to start Synergy and run KAPCOM. I tested it all out and the trackball worked great. KAPCOM is currently in a broken state because I'm still working on the configuration changes for adding multiple modes and Arduinos.Very happy with the progress I'm making. I'm going to spend some time at lunch working on the mode and Arduino code. Once I get that done, I can go back to working on the enclosure.
lawnmowerlatte
