Not laggy ECS's
A project log for Arcus-3D-M1 - Full Color Filament Printer
Active mixing, fused filament fabrication 3D printer.
masterofnullMasterOfNull 02/24/2016 at 04:230 Comments
This is what it should do.
Mixer spins in lockstep with current extrusion rate, which is calculated from print head velocity.
I've slowed the mixer speed here so you can see it spin and it has time to stop between lines.
Not printing anything here. Just going through the motions.
