Hackaday.io Hackaday.io
Sign up Log in
Light Glove - Pro Trinket + ESP8266
A glove built with Pro Trinket and ESP8266 that catches color and throws it as MQTT message for other devices to consume
mohanMohan
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2.6k views
0 comments
430 followers
  • Description
  • Details
  • Files 0
  • Components 5
    • View all
  • Logs 0
  • Instructions 1
    • View all
  • Discussion 0
View Gallery
2.6k
0
430
5
Team (1)
  • mohanMohan
Join this project's team
  • Blog Post
hardware
completed project
mqtt ESP8266 element14 Pro trinket TCS34735
This project is submitted for
  • Hackaday.com Tip Line
This project was created on 01/04/2015 and last updated 12 years ago.
Description
I built this glove as part of the Element14.com 2014 IoT holiday lights contest. I used a Adafruit Pro Trinket, a color sensor and ESP8266 to catch the colors and send it out as MQTT messages that can subscribed by other devices with MQTT capabilities. ( for example a LED wall washer or a LED Strip driven by a Arduino Yun or other WiFi capable devices. )
It can be easily modified to use other communication protocols instead of mqtt.
The full build log is at here at element14.com
http://t.co/N4yPzvOmlH
Components
  • 1 × Adafruit Pro Trinket 5v
  • 1 × ESP8266
  • 1 × Adafruit TCS34735 Electronic Components / Misc. Electronic Components
  • 1 × Flex Sensor Electronic Components / Misc. Electronic Components
  • 1 × Resistor and other necessaries
Build Instructions
Collapse
  • 1
    Step 1
    Instructions and source code links at http://t.co/N4yPzvOmlH
View all instructions
Log In/Sign up to comment
Sign up with Github
OR
Make your ideas come true!
Project Owner Contributor
Ever been drawn to those colorful little lights?
ai-thinkerAi-Thinker
Use 3 amplified LEDs to sense alarm status LEDs. Send the status to the internet and Smart Apps using Arduino with Wifi shield.
SMAFDAPs (Smart Apps For Dumb Alarm Panels)
eric-livesayEric Livesay
The 2015 Hackaday Prize
Take 1 AC Lamp, a uController, a normal LED bulb and some color LED strips to get a functional lamp that also can send colored alerts.
Smart Lamp Notification
neil-cherryNeil Cherry
The 2016 Hackaday Prize
Sub $10 RGB LED Mood light that you can control over WiFi embedded HTTP web server
RGB WiFi Web controlled LED Mood Light
jovanJovan
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Light Glove - Pro Trinket + ESP8266", please tell us the reason.
Send message
Remove Member
