Got the boards, and this is the assembly as drawn, I am only building 1 because I am pretty sure heat will cause a failure, but I will torture test it and find out.
Here is the board with what will probably be the final assembly (hopefully).
A project log for 12v Motor Driver
This board is to drive a 12v 5A motor using a microcontroller.
