Boards
01/17/2015 at 02:14 • 0 commentsGot the boards, and this is the assembly as drawn, I am only building 1 because I am pretty sure heat will cause a failure, but I will torture test it and find out.
Here is the board with what will probably be the final assembly (hopefully).
First Build
01/07/2015 at 01:16 • 0 commentsBreadboarding was successful. The design is at the board house, I will post if the design was good or not.
