Nothing really to add here except a few simple glamour shots to show how things ended up. Connected, in this case, to a Due just for fun.
A project log for Arduino-Compatible FPGA Shield
Spartan 6 FPGA Shield includes SPI Configuration Flash, Breakout Headers, SRAM, programmable from Arduino or SPI Programmer
How does the Arduino programming part work? Do you load a sketch that works as the programmer then push the .bit file in over serial?
