As a first approach i wanted to find out how to count the time between two button presses. Based on this project I would use a one second watchdog timer in interrupt mode to increment a counter:
ISR(WDT_vect) { seconds++; }
Instead of the buttons being pooled, I also implemented a hardware pin interrupt. When the interrupt occours, the ISR function is called with the PCINT0 vector, as this:
ISR(PCINT0_vect) { unset_interrupt(); switch(button_press) { case START_P: start_second = get_seconds(); blink(3); break; case STOP_P: stop_second = get_seconds(); blink(2); break; default: break; } button_press++; duration = stop_second - start_second; if(button_press>=3){ for (i=0; i <duration; i++) { blink(1); } button_press = START_P; } set_interrupt(); }The unset_interrupt() function stops the hardware interrupt, eliminating interference, and after running the code, we use set_interrupt() to re-enable the hardware interrupt.
The function get_second() gets the current second, using atomic operation, from the seconds variable.
int get_seconds() { int current_second; ATOMIC_BLOCK(ATOMIC_FORCEON){ current_second = seconds; } return current_second; }
The next step I want to take is to eliminate the _delay_ms() functions of my code, do a little clean up and advance with the shutter part.
