monitor water level with ultrasonic system to better than 1/2" allows for calculating water usage and also water leakage with sufficient accuracy.
system could also shut down tank outlet if major leak determined. would also have to shut down pressure pump...
system would report usage data and alarm status through webpage interface, phone app, etc.
abraxas1
