So 5V from one source seem to work just fine - a pcb might help correct loose wires an hot-glue mess ;)
I designed 2 iterations of rolls for the front but finally bought one on eBay for 5 Euros.
A project log for R8-D8 - a distant relative of R2-D2
a 12cm radius, 3d printed R2-D2 with some motors, servos and blinky stuff that follows lines, persons or just drives around via bluetooth
Hah! Was wondering if you ever got it working... looks good! No more power/noise-issues?
I had him running round a bit with the OSHPark L293D board, but the app I used to control it over bluetooth was sending some weird stuff so it was unrecognizable and the front roll got stuck and was actually more breaking than rolling. So I ordered the metal ball thingy which can be seen in the picture and installed it the day before yesterday. I controlled it via bluetooth serial terminal, just sending 't', 'r' and 'l' as characters.
