I just finished soldering the components on the latest PCB. Did some testing and everything seems to work. Had some problems with the volume at first, it would change randomly when i got close to the PCB. I think a bad ground connection caused this. The USB-cable i used was very loose in the connector and when i changed the cable everything was fine.
Andreas Dahlberg
