Had to speed much of the morning on a conference call where I was only needed if there was issues for my team. We had no issues so I had 5 hours of listening to other people work out issues. While setting here I found a few things to play with. Here is a simple quick robot build.
There is an official boe-bot arduino shield but no need for one if you already have the boe-bot. My boe-bot came from a project my son did in high school. They did some basic stamp/robotics programming and this was the left over frame. The stamp and other parts have been scavenged for other projects.
Components
1×
Paralax bot-bot chassie.
Need the frame, 2 servo's and the roller wheel in the front.
1×
Any Arduino
Most any model will work
1×
Arduino proto shield
Not needed if you want to hardware your project.
attach the servo's to the chassie and feed the servo wires through the slots at the back of the frame.
2
Step 2
Using standoffs mount the arduino to the frame. My Arduino was in a holder but you can mount the Arduino directly to the frame if you dont have the holder.
