It's handy to have gcc output errors for certain things...
e.g.:
uint16_t a = 512;
uint8_t b = a;------
In my code, I prefer to have it explicitly stated that I want to "downsize", so I don't mistakenly do that.
So, as I recall, there's a gcc-warning option for that, and further a means to convert that warning into an error.
Here's a listing from my makefile.
The remaining are CFLAGS for -W... arguments
# Warnings that I would rather be considered errors...
# THESE ARE gcc-version specific! (Apple's GCC 4.01 doesn't like 'em)
#WTF, seriously... this should *not* be a warning, but should be an error:
#warning: integer overflow in expression [-Werror=overflow]
# (((uint32_t)(TOGGLETIME * 8))<<(highNibble)),
#from heartbeat1.50
CFLAGS += -Werror=overflow
# Stupid Mistake: strcmp(0==instruction,"test")
# should have been 0==strcmp...
# Gave a warning, but wanted to convert that to error-material, nogo.
# Apparently only works when int is of the wrong size for pointer...
#CFLAGS += -Werror=int-to-pointer-cast
#-Wstrict-aliasing?
# Specifically missing return value
# This is handled with -Wreturn-type "falling out of a function is considered returning void"
CFLAGS += -Werror=return-type
# Watch for use of uninitialized variables...
# This does not handle volatiles! Does (attempt to) look for uninitialized array elements.
# This apparently isn't very smart and is optional because of that. See the manpage
# I'd like to think it's possible to code things so it can be detectable, we'll see.
# Problems? "Some spurious warnings can be avoided if you declare all the
# functions you use that never return as 'noreturn'."
CFLAGS += -Werror=uninitialized
#THIS IFNDEF is a hack... the old avr-gcc doesn't have this option
# Would be better to test these options in GCC before compiling... TODO
ifndef CC
# That's basically useless in all but the simplest cases, as is:
CFLAGS += -Werror=maybe-uninitialized
# Neither detect:
#int main(void)
# int result;
# if(rand()) //may be 0
# result = 1;
# printf("%d\n", result);
# return 0;
# And haven't for over a decade. Except, apparently, Apple's GCC4.0
endif
# This case is just BAD and should not be allowed ever.
# int i = i;
CFLAGS += -Werror=init-self
# The next two could be handled together with "implicit"
# Implicit declarations (no type specified: e.g. "static i;")
CFLAGS += -Werror=implicit-int
CFLAGS += -Werror=implicit-function-declaration
# Detect global functions that aren't in headers...
# This one's kinda annoying... useful, but annoying
#CFLAGS += -Werror=missing-prototypes
#CFLAGS += -Werror=missing-declarations
# Might want to look into -Wignored-qualifiers
# also -Wmissing-braces (just to be paranoid about array-initialization)
CFLAGS += -Werror=missing-field-initializers
# Watch parentheses and nesting... mainly:
# if (a)
# if (b)
# foo ();
# else
# bar ();
CFLAGS += -Werror=parentheses
# Watch out for undefined stuff like a = a++;
# do not fall into these habits as "more complicated cases are not diagnosed"
CFLAGS += -Werror=sequence-point
# Watch out for switches without default cases... I consider this bad practice
# Who knows what'll happen if an integer's bit is affected by protons?
CFLAGS += -Werror=switch-default
# Do not allow float comparisons that are ==
CFLAGS += -Werror=float-equal
# Don't allow bad address comparisons (if(func) instead of if(func()))
CFLAGS += -Werror=address
# Might also want to look into int-to-pointer-cast and pointer-to-int-cast
# Watch for pointer argument passing and assignment with different signedness
CFLAGS += -Werror=pointer-sign
# Stop on the first error
#CFLAGS += -Wfatal-errors
# Warn for variables that might be changed by longjmp or vfork.
CFLAGS += -Wclobbered
# Warn about implicit conversions that may alter a value
# Annoying... especially when using a uint8_t as an array position uint8_t i; noteList[i];
#CFLAGS += -Wconversion
CFLAGS += -Wsign-compare
# -Wstrict-overflow looks worthwhile for many reasons... watch out for optimization errors!
CFLAGS += -Wstrict-overflow=4
# Warn if an undefined identifier is evaluated in an #if directive.
CFLAGS += -Wundef
Note, I'm certainly no expert on these things. I just, one day, sat down and looked through 'man gcc' and compiled this list as best I could from what I understood that day. Most of it I've *long* since forgotten... hopefully those comments are clear :)
(If the text wraps weirdly, sometimes *shrinking* your window-width will help, counterintuitively)
Eric Hertz
