So I'm working on porting someone else's thing to another thing...
That "someone else" happened to use some pretty specific things to access their thing, and I'm working on abstracting those specific-accesses to work with my thing... (I'll call it my thing, merely in expression of differing it from the other person's thing which doesn't yet work with the thing I'm trying to make it work with, for my own purposes, which in-so-doing might just make it work with many others' things, with much less effort than currently necessary to make that person's thing work with other people's things).
hmm, sounds a heck of a lot like what I've been doing here... Abstracting things...? And, low-and-behold, in-so-doing, I've been kinda converting that thing to make use of this thing in order to make it work with mything. Hmm...
But, I don't particularly want to release "this thing" (nor most of my things) in its entirety via the typical licensing-thing that these things are typically licensed-under--despite the fact that that licensing-thing is exactly what enables things like this to become so common-place in the first place--because, frankly, there're a few side-things in that licensing-thing that I don't particularly agree with subjecting my efforts toward.
So, rather'n forcing this thing upon that thing, and either sacrificing my preferred-licensing-thing over their licensing-thing or forcing my licensing-thing upon their-thing, I'm thinking, instead, to release *portions* of this thing under that/their-licensing-thing as a means to (hopefully) better their thing and maybe even finally see this thing begin to enter into the usefulness-playing-field, to boot.
Who knows, it could be all hogwash, but it's a new concept I hadn't considered before...
I'll be less abstract when I actually get that thing working on my thing. But, as it stands, it looks like this thing is merging into that thing quite a bit more smoothly than I first-expected. Fun things!
Oh, for a tally, the new thing, so far, takes 6 bytes more program-space than the original thing, out of nearly 32KB, that ain't bad. And, I think, actually, that 6 bytes may be largely due to a mutex-bug I found/fixed in "that thing." So, in fact, it could be that all this abstraction and the benefits it may gain that thing might, in effect, have no noticeable *functionality*-consequences whatsoever... Which, admittedly, was kinda a big part of the goal, but a really nice surprise to see verified.
