Build video! I make two different versions.
Just a Hot-Key Panel that uses "arcade" style buttons and an Adafruit Trinket to mimic keyboard inputs.
TinketHolder.stlA Small holder for the trinket if you would like to use double sided tape to attach it to soemthing.Standard Tesselated Geometry - 204.08 kB - 01/22/2018 at 16:00 |
3DPrint_HotKey_Panel.stl3D printed version of the hotkey panel.Standard Tesselated Geometry - 192.07 kB - 01/22/2018 at 16:00 |
HotKey_Panel_Dim.pdfDimensions of the Acrylic non 3D printed PanelAdobe Portable Document Format - 22.48 kB - 01/22/2018 at 16:00 |
3DPrint_FacePanel_HotKey.pdfAcrylic facepanel template for the 3D printed version.Adobe Portable Document Format - 15.98 kB - 01/22/2018 at 16:00 |
HotKey_Panel_NoDim.dxfDimensionless DXF version of the acrylic version.AutoCAD DXF - 11.42 kB - 01/22/2018 at 16:00 |
Hello,
If I want to build this project in arduin uno, I think I should change pins 0,1 that correspond to those of TX RX?
