11Step 11
Install the Power Relay Mechanism
The manual transmission's exiting reverse gear can be now operated using an AC motor. Replace the gear changing mechanism with an electrical switch. Lastly, install relay switching mechanism which connects and disconnects your car from its batteries. So, now it is the switch which turns your car "ON" and "OFF". Now connect the ignition switch with the relay, in order that the relay gets operated via the ignition switch. You can install a different charging mechanism for your car's batteries. Place a charging socket on your car's exterior and then wire the whole charging mechanism with it.
12Step 12
Time to Test
If you have manages to put all the things properly, your car is ready for testing. Individually test each and every part. Test the working of controller with accelerator pedal. When you end up with the testing stage, you are all set for the electric car's test drive. And once that goes efficiently and successfully, you're ready for pollution free and smooth drive in the electric car!
Don't forget to compare car from other Electric Cars available in the market.
